993 Forum 1995-1998
Heater Blower connector question
Old Jul 27, 2010 | 02:33 PM
trophy's Avatar
trophy
This is a little OT but does anyone have a close up photo of the circled area? I need to know what color the wires are and what order (front to back) nine broke and I dont know which to solder where...... Hijack OVER...
File Type: jpg
Old Jul 27, 2010 | 08:11 PM
IXLR8's Avatar
IXLR8
Originally Posted by trophy
I need to know what color the wires are and what order (front to back) mine broke and I don't know which to solder where.....
Hey, that engine bay looks familiar...and is it ever dirty.
Front wire: Green with white stripe.
Rear wire: Red with white stripe.
Old Jul 28, 2010 | 12:16 AM
trophy's Avatar
trophy
Thanks Alex, just what i needed ( i was going to mention the dirt.....)...... Back to the regular programing.
Old Oct 26, 2011 | 01:41 PM
HalM3's Avatar
HalM3
I know this an old thread but still related. I have a 95 and attached to the driver's side fuel rail are three conenctors that are unused. I can see the two very short ones have no home but what about the long two wire conenctor with the brown and red wires?
Thanks.
Hal
Old Oct 26, 2011 | 03:53 PM
MDamen's Avatar
MDamen
I believe those go to the heater blower. I'll check my car tonight to confirm.
Old Oct 26, 2011 | 08:15 PM
HalM3's Avatar
HalM3
We have a connection on the blower motor that is different. It could plug into the tube but the twin yellow wires and the connector seem to be for this piece. The odd man out is the longer two connector with a red and brown wire and a square plug.
Old Oct 26, 2011 | 09:54 PM
HalM3's Avatar
HalM3
Old Oct 26, 2011 | 10:00 PM
HalM3's Avatar
HalM3
Here's a better view of the plug we're trying to find a home for...
Old Oct 26, 2011 | 10:17 PM
rsr91128's Avatar
rsr91128
Your car is an early 95 without the fresh air flap that has had the wiring harness recall done.
The replacement harness is for all NA models so the early cars will not use the "switch over valve" plugs.
IIRC there were 2 for the fresh air flap and 1 for the Vario ram flap, so if you look closely you will find the three plugs on the left side of the engine. Can't remember the colors off the top of my head but that is one of them.
You can see the breakdown of the plugs from the recall TSB below. In the diagram the extras for your car are #12,13 and 17.
If you need the colors I can take a look, but mine are all tied up behind the intake out of sight.
File Type: jpg
File Type: jpg
Old Oct 27, 2011 | 12:48 AM
HalM3's Avatar
HalM3
That should do it. Thanks for everone's help. I'll do the same and tuck them away behind the ducting.
