Interior Pics for Track Car
Rennlist folks,
Thought I'd post a few photos from my interior re-do of my '96 C2 track car. I've used a lot of old posts on Rennlist as inspiration and maybe someone will do the same with this post. Over the past 10 months I"ve gone from a stock midnight blue/marble grey interior to a "track look" (for lack of a better term) black interior. I'm happy with the results so far. Enjoy!
I've done the following:
Black vinyl paint on dash, door tops, rear seat panel, and key surround
Removed knee pad panel and glove box
Installed Rennline under dash panel
Black dye on A pillar vinyl
Removed all rear seat pieces, all carpet, sound deadening, and glue
Retaped all wiring
Installed leather RS door panels from AppBiz
Installed Rennline pedals
Removed all center panel pieces, relocated buttons to dash with Rennilne face, cut off/drilled out metal brackets on center console
Primed all metal interior surfaces
Removed airbag wheel, installed Momo Mod 7
Black spray paint on wooden floorboard
Black spray paint on plastic cover for footwell
I plan to do the following:
Rothsport shifter and black leather boot
Paint all interior metal surfaces with black urethane paint
New threshold pieces
Under-dash (hidden) ipod amplifier
Retaped all wiring
the center console area looks nice and open the way you've done it, and will look even better with the rothsport shifter.
I painted those plastic foot well covers also, used the textured shimmer black so they look metallic.
I can't believe you got all the glue and tar paper off the center console! that must have been tons of work. I gave up trying to remove all the glue and just installed the rs carpet set.
what's the purpose of an ipod amp?
pull the wiper relay and the wipers can be parked any place. my seat is low for helmet space, so I park the wipers on the passenger side also.
Sorry about the threadjack, but could you elaborate on this??
Love my car but on my short list of annoyances, the wipers being right in my face all the time is probably on top..certainly sounds a lot easier than pulling the linkage and such out!
The ipod amp will be for long drives to/from various tracks, I still have the rearmost speakers in.
And yes, that's exactly what I did with the wipers. My seat is also low and having the wipers on that side really improves the view.
fuse cover in frunk, flip over and find the wiper delay relay. pull it and you obviously lose this function, but you can turn on the wipers and stop them anywhere on the windshield you want.
ahhh...propane torch. guess I gave up too easily.
I gave up on speakers, amp and cdr too, it was 5lbs here, 3lbs there. I just use ear buds and ipod if I get tired of the engine sound.
the ipod amp is a great idea though. that and some light weight door speakers and I'd have a car stereo again.
please post when you find one.
Oh ok...so if I am interpreting this correctly, this won't work if retaining the delay function is desired (it's pretty much necessary in the northwest!)? Or does it stay parked on the other side once the relay is reinstalled?
delay function won't work. even worse is you lose the toggle wipe where you flick the stalk up once and the wipers do one pass. the wipers are either on or off, and stop in place when you turn them off.
since there is always something falling out of the sky in seattle, you might find it annoying to lose the delay feature.
Don't think that's Bill's car, as his console is pictured above above. Nontheless, I'd love to know where one could source that short one.
I remember a thread in which the gauge installation was outlined; it may be a secondary oil temp gauge (edit; nope).
I cut the factory console just rear of the opening for the shifter boot attachment and used some of the cut off side piece to glue in across the rear of the console. Used body filler to contour the piece and then had an interior guy cover it.
The boot I had custom made by the dreaded Alan Gun Leather. I needed to cut off the handle it came with because it was so bad. The Rennline handle worked out nice. I slotted some carpet and attached it with Velcro where it goes over the hand brake cable adjuster.
Guage is a voltmeter.
Mike
Mike
