fitting rear spoiler ?
Guys, my RS M002 spoiler is one fully formed piece so if i place it onto the rear lid and screw up into it I cannot get a nut onto the reverse side as its 'inside' the formed spoiler. Do yuo have to use self tapping screws or somehting ? I would have though that that wouldn't be anywhere near secure enough ?
Also, when I place the spoiler onto the lid, the mounting surfaces aren't flush because of the old nuts that used to hold the standard motorsied spoiler. These look like they were painted at the same time as the lid so the paint has sort of melded them as if they are captive. Presumably I need to dislodge these and get them out of the way ?
any help appreciated
if so here's mine
all the parts have to be removed from the moveable spoiler the new one sits in the depression left.
here are the bolts
4xM4x14 & 4xM5x16 & 8x A5,3 washers
Note what seems to be an obvious taper from the lead-in to the shoulder of the screw.
good luck
guys here is the issue
to get the spoiler flush I need to remove these 6 nuts which were necessary for the OEM standard C2 spoiler
they look like theyve been painted same time as the car
in fact they look like they are captive and actually have 2 small welds either side ???
does anyone recall these ? I tried pulling on one but it seemed stuck fast. I don't want to bend up the metal there but then if I don't remove them then the spoiler does NOT sit flush with the holes on the top and bottom ?
