Another Air Con question......
When the air conditioning is on......there is a " Shhhhhhhhhhhhoup " sound
that lasts for about 5 - 10 secs, and this would repeat about every minute continuously. It sounds like an air flap is opening and closing.
Sure appreciate if anyone can shed some light to what's going on......TIA !
_____________
'97 Blk/Blk C2S
_____________
'97 Blk/Blk C2S
I'm no expert, but I did find the vacuum leak that caused the so-called wheezing sound when I activated the MAX A/C button.
You might have a vacuum leak.
You may have a vacuum problem as already suggested, or a stuck air valve servo somewhere, probably the fresh air servo. My website gives the details:
www.ccu.tore.bergvill.com
Cheers,
Tore
Cheers,
Tore
Hey Tore,
Thanks for the link...great information !
Looks like its beyond my limited DIY ability, I'm in LA area of So Cal, anyone have any recommendation to who to go to for air-con repair? Of course I will check with Robin and Chris first !
____________
'97 Blk/Blk C2S
____________
'97 Blk/Blk C2S
