993 Forum 1995-1998
Gear oil/fluid change??
Old 07-14-2010, 07:09 PM
bgiere
bgiere's Avatar
Grainger has Delvac SHC as well. I get it over the counter here in Cleveland or you can mail order. A tad less $$ than I've seen elsewhere.
Old 07-14-2010, 07:19 PM
Bill Verburg
Bill Verburg's Avatar
Good to know, it's also in the Porsche system;
Getriebeöl Mobilube 1 SHC 75W 90 gearbox oil 999.917.062.00
Old 07-14-2010, 07:49 PM
AOW162435
Seared
AOW162435's Avatar
Originally Posted by Quadcammer
delvac here as well.
lufteknik sells it.
Yep.
Andreas
Old 07-14-2010, 08:16 PM
johnsjmc
johnsjmc's Avatar
Just changed the lube from unknown but clean to Redline 75w90 NS. I have noticed an improved downshift into 1st already. Before I could get a crunch at any speed above zero . I can now downshift at a low speed roll. I am sure I still need syncros replaced on first but I may be able to delay it until the clutch goes.
Old 07-15-2010, 12:17 AM
Renaud Bizet
Renaud Bizet's Avatar
Newbie question, I just did mine with Delvac a few weeks ago but I have a LSD.
Do I need to add some special additives too?
Thanks !!!
Old 07-15-2010, 12:43 AM
arcteryxbird
arcteryxbird's Avatar
+1 redline
but she hates quickshifting
Old 07-15-2010, 08:35 AM
Bill Verburg
Thanks !!!
no
Old 07-15-2010, 10:40 AM
JPS
JPS's Avatar
Any different choice for RS gears / clutch / LWFW? I changed it once due to a crazy rattle and it helped for awhile...but seems to be back a bit.
Old 07-15-2010, 12:48 PM
Bill Verburg
the /3x series does make more noise than the /2x series because of the extra 'loose' gears but factory fill is SHC/Delvac for all of the cup transmissions.
You should hear the rattle in a Cup car w/o any insulation at all, you'd swear it was going fall on the ground in a million pieces
Old 07-15-2010, 01:12 PM
Renaud Bizet
Originally Posted by Bill Verburg
no
Thank you Bill
Old 07-15-2010, 02:35 PM
JPS
JPS's Avatar
I've received quite a few odd looks at intersections, drive throughs, etc. Even my wife thought it was going to blow itself up...
Quick Reply: Gear oil/fluid change??
