dented oil filter
dented oil filter
rrr just one of those diy days when all seems to go wrong. My factory oil filter wrench got stuck on the new small filter that is on the engine. In my attempt to free the wrench i dented the end of the filter ie the flat bottom got pushed in. did not have time to drive the car but when i thought more about it, I wondered if that could create an obstruction? What do these filters look like inside is that a critical area for oilflow? I will replace it if necessary? i have done this diy many times with no prob rrrrr
Hi
I would not worry at all. If the filter was side mounted I would be a little concerned bacuase sometimes thay have an anti drain valve in the bottom, and I suppose that you could damage that.
Berni
Berni
