993 Forum 1995-1998
PSS10 vs. KW Var3
Old Jul 2, 2010 | 01:48 AM
FLYT993's Avatar
FLYT993
Default PSS10 vs. KW Var3
Just curious...which the forum thinks is the better set up for our cars...the 10's or the Var3's???
Old Jul 2, 2010 | 02:39 AM
alexl911's Avatar
alexl911
Unless someone has installed both systems in their car, I doubt any answer you get will be objective. Even driving two cars side-by-side is not a good comparison unless they have exactly the same geometry, tires, mileage, bushings, etc..etc...
I have the KW Club Sport (recently upgraded from V3) and am very happy with it but my requirements might be different from yours.
Old Jul 2, 2010 | 03:14 AM
FLYT993's Avatar
FLYT993
astute observation! thanks!
Old Jul 2, 2010 | 02:33 PM
mcipseric's Avatar
mcipseric
pss10s 2 way adjustable
kwv3s 3 way adjustable
Old Jul 2, 2010 | 02:39 PM
cgfen's Avatar
cgfen
definitely KW V3
i "love" the purple spring mounts..................
i currently have P10's
sorta wish i would have bought the V3's
the best thing about P10's = ability to tune handling characteristics for various AX tracks
the worst thing = harsh ride even when set to soft
KW's? should have same + more adjustability, compression AND rebound
and
rumored to be "less harsh" when set to soft.
I'm close to selling my P10s to a friend and getting the V3s
If you ask this same question on a UK based forum, betcha most people would say K3 is the way to go.
PM jmarch, he recently installed a set.
cheers
Craig
Old Jul 2, 2010 | 04:56 PM
boulderbobo's Avatar
boulderbobo
I have PSS10s on my C2. I run the compression/rebound at 4 clicks F and 5 clicks R. I use the car primarily for spirited driving. In my opinion, the PSS10s are not harsh. I would characterize the PSS10s as firm but compliant. As a comparison, I have a Stasis StreetSport suspension my my B5 Audi S4. I set the C/R in the middle of th adjustable range. Now this suspension is harsh.
Bob-
Old Jul 2, 2010 | 05:43 PM
timothymoffat's Avatar
timothymoffat
I've got the older PSS9s on my 95 and LOVE them. I would say they offer a great ride (mine are set on 4 all around, 1 being the stiffest) and greeat wheel control. My 97 currently has H&Rs/Bilstein HDs and I find the setup less than ideal. Can be a bit harsh over sharper bumps and seemingly less wheel control than the PSS9s. I'm going to be replacing this setup with KW V3s in the near future. I know, not much help now.
Old Jul 2, 2010 | 07:05 PM
ABCar's Avatar
ABCar
I have P10s...I really like them and dont feel they are harsh at all. 3 on F 4 on R. pretty damned good in my op.
Old Jul 2, 2010 | 07:12 PM
cgfen's Avatar
cgfen
Originally Posted by timothymoffat
I I'm going to be replacing this setup with KW V3s in the near future. I know, not much help now.
a perfect guinea pig!
love to hear your P10 vs KW comparo thoughts when you make the move from HD's.
cheers
Craig
Old Jul 2, 2010 | 07:35 PM
kjr914's Avatar
kjr914
Close doesn't count except in horseshoes & hand grenades...
Tim, get on it! And convince Craig of KW superiority! That "friend" is waiting for those PSS10s...
Old Jul 3, 2010 | 03:39 AM
alexl911's Avatar
alexl911
Does this help: https://rennlist.com/forums/993-foru...torsports.html
Old Jul 3, 2010 | 07:47 AM
David in LA's Avatar
David in LA
I have KWv2 on the Turbo and wish I had v3...just can't justify the cost for replacing since the setup is perfectly dialed in now
