O.T. - What's the best lawnmower?
#46
Exmark with the Kawaski motor is much better than the Honda motors. The Kawaski has a oil pump so it is presure feed lubricated. The Honda, splash lubricated on both the OHV and OHC motors. Kawaski, spin on oil filter. Honda, what oil filter.
I am in the heavy equipment business, CAT, and on our rental side we run and sell so many small pieces of equipment, pumps generators etc... that run either Honda, Robin(whicn is Subaru) Briggs and such. And my point is that there are a lot of problems with the Honda's and they are just OVER RATED. And I can back this claim up with novels of warranty claims if anyone wants to challange my statement..
Bottom line the Kawaski is a much superior engine and Exmark is the only manufacture that I know of that uses them.
#47
I moved away from the city to get away from polution and now I'm going to develop a phobia of using my new mower. I really find that statistic hard to beleive. Maybe a Buggati powered lawnmower.
#48
I have a Craftsmen with a Honda motor which I really like. One feature it has that is great is a clutch. Normally the safety bar stops both the motor and the blade. One mine it disengages only the blade, makes those quick stops to move a stick or rock much easier.
#49
#50
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
#51
I use a JD rider for the lawn and a cheap Sears w/6 HP engine for cutting weeds/brush.....it cost $139 over 10 years ago and I just change oil and filters and sharpen the blades.
#52
It's pretty simple - most mowers have very crude/non-existant emission control devices compared to modern passenger cars because I don't believe mower emissions are usually regulated. You don't have to smog your mower because it's an "off highway" pollution source. I always thought that this distinction was totally absurd in that polluted air easily blows from the "off highway" location (like your yard or your neighbor's) to where you live, sleep and breathe.
#53
Here is a plug for Honda. A friend of mine's home was flooded during the recent flood in Nashville. He has a Honda lawnmower that he was going to pitch as it had been submerged under 4' of water twice that weekend. I told him that it was a Honda and I bet it will start w/o a problem. So I took it home drained the water out of the crankcase and fuel tank, drained the oil (yep) out of the carb bowl, took off the valve cover and sprayed WD-40 all through it. I then filled and drained the crankcase twice with Mobil 1. It started with two pulls! I was amazed.
#54
Guess the mower and handheld equipment manufacturers are wasting time and money meeting those non-existent emissions regulations.
Phase 3 for small gas engines:
http://ecfr.gpoaccess.gov/cgi/t/text....1.1.9&idno=40
Diesel mowers have standards also, tier 4 info:
http://www.dieselnet.com/standards/us/nonroad.php
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
#55
Husqvarna Lawn Mowers can be great for your lawn and is most trusted by most of its users for its innovation. This Auto Mower does the entire task for you and you can sit and relax.
