993 Forum 1995-1998
Sponsored by: DashLynx
OPTIMA Batteries
Old 06-21-2010, 04:21 PM
95_993
95_993's Avatar
Default OPTIMA Batteries
I noticed a number of folks that have gone with the OPTIMA battery. Are there any drawbacks (other than cost)? Are they that much better? Can I use my std. trickle changer during storage?
Old 06-21-2010, 04:43 PM
TheOtherEric
TheOtherEric's Avatar
The main drawback is that they are complete pieces of ****... you'll be lucky to get 2 years from one.
Other than that, they're great.
I believe I'm on my 4th.
Old 06-21-2010, 04:50 PM
Akerlie
Akerlie's Avatar
The yellow tops are good, the red tops are crap.
I bought a Odyssey battery for the porsche but i use Optima yellow tops in the Jeep.
Old 06-21-2010, 04:54 PM
NC TRACKRAT
NC TRACKRAT's Avatar
I'd say that the No.1 advantage is the virtual elimination of battery acid damage. Lots of posts for OPTIMA, ODYSSEY, BRAILLE, etc.
Old 06-21-2010, 05:24 PM
Van Larson
Van Larson's Avatar
Default Optima batteries
FWIW, I have used Optima's in a variety of daily driven vehicles for 10+ years. I write the "in use" date on the top. Currently, 2 vehicles (daughter's WRX, my 92 964) have red tops of 8 and 6 years age, respectively--no problems, no defects.
Old 06-21-2010, 06:33 PM
gr1275
gr1275's Avatar
I have had the red top in the turbo now for five years. No problems... although I do keep a trickle charger on it as it sits for a month or more at a time. I have had one in the street rod for eight years without a problem.
As for performance, I'm not sure they actually out perform a good lead acid battery. I've had good luck with them over the years and are comfortable with the cost.
Gary
Old 06-21-2010, 07:05 PM
vincer77
vincer77's Avatar
I installed a Yellow Top in my car. Not an exact fit, but it does fit. I am hoping for longer life, but I am especially fond of the no leak feature of the battery design.
Old 06-21-2010, 08:19 PM
2Many Cars
2Many Cars's Avatar
I have a red top that is now about 5 years old. I went through 2 others in about 1 year before this one (both were warranty returns). Once you get a good one they work great but be sure you have a proper charger/maintainer that is designed to work on Optimas, not just a run of the mil trickle charger as those can contribute to early failure.
Old 06-21-2010, 08:28 PM
TheBen
TheBen's Avatar
isnt there a special bracket (from Rennline) that allows these to fit securely?
Old 06-21-2010, 08:40 PM
vincer77
vincer77's Avatar
Looks like they make brackets for "Odyssey" dry-cell batteries - not the Optima.
Old 06-21-2010, 08:48 PM
95_993
95_993's Avatar
What size is a direct fit for 993? They don't list Porsche in their application guide. I think I saw Model 35 somewhere in my search, but wanted to confirm. Considering the Optima vs Odyssey. OPTIMA is $85...might be worth a try.
Old 06-21-2010, 08:58 PM
vincer77
vincer77's Avatar
Mine is a 35. It is not a "direct" replacement, but it fits.
Old 06-22-2010, 09:57 AM
gr1275
gr1275's Avatar
I'm using a #35 in a 964 along with the OEM tie down. Although it's a touch taller, it's small enough in the other dimensions to leave enough room for a battery cut-off on the negative side.
Gary
Old 06-24-2010, 12:25 AM
shu
shu's Avatar
I recently installed a 35 red top. Other than a slight mod to the oem bracket, fits perfect
Old 06-24-2010, 12:31 AM
fast_freddy
fast_freddy's Avatar
I had a new Optima in my car when I bought it in late 2004. It was shot within 18 months. Replaced it with an OE "Porsche" battery which lasted a little over two years. Now I have an Odyssey, lets see how that goes.
Quick Reply: OPTIMA Batteries
