993 Forum 1995-1998
offset question...
Old Jun 4, 2010 | 01:44 PM
911ist's Avatar
911ist
Default offset question...
sorry to post yet another topic that's been beaten to death...but I can't seem to find an exact answer so here it is again.
what is the lowest offset I can have on a narrow body, without rubbing, to make the wheels as flush as possible to the fender? I am using 225/40, 265/35 tires, 18x8.5, 18x10 wheels.
thanks
Old Jun 4, 2010 | 02:07 PM
TheOtherEric's Avatar
TheOtherEric
You'll get a variety of comments, but IMHO you can probably do ET55 with 265 tires if you really need to. Maybe a smidge less but it'll start looking funny beyond that. Not sure what the 8.5" wheel will do to ya.
Are you lowered? If so, how much?
Old Jun 4, 2010 | 02:23 PM
911ist's Avatar
911ist
yes, lowered on H&R for now. PSS10s will be coming soon and I plan to be on RS height.
Old Jun 4, 2010 | 03:34 PM
David in LA's Avatar
David in LA
ET52 with 9"/10"/11" rims and rolled fenders for rears but depending on tire brand/model as well as size. Front 8.5" you can go ET40 w/ slight fender rolling; ET45 w/no rolling...OK with 245/35.
What wheels are you considering?
Old Jun 4, 2010 | 09:48 PM
Bill Verburg's Avatar
Bill Verburg
wheel fit is like pants fit everyone is different.
for wheel fit it depends on ride height, alignment, specific tire.
for 8.5 on a low car w/ 245/35 tires and a track alignment(lots of neg camber) I'd go no lower than 56
for 10 same situation as above but w/ up to 285/30,ET65
at higher rides heights you can use lower o/s
