Are the stock Studs Long Enough to fit a Strut Brace?
Do you guys just fit the Front strut tower Braces as is or do the studs need to be replaced for longer ones, Because it doesent look as if there is much room there.
Don't know which brace you have, but the standard RUF brace will not work with the stock upper mount studs - they are too short. You will need to replace with 24mm studs.
