Steering wheel shaking at exactly 60 mph
Seared
Addicted Specialist
Me between exactly 55-60, but smooth as silk everywhere else ...ah hem, even markedly north of 60mph. Everything checks out, and it has been like this for some time without any change or degredation whatsoever. I choose to live with it until I feel something merits attention, personally.
Edward
Edward
Wheel bearing/s? Internal fault/s in tire/s? To check for internal faults, raise tire pressure to 50 psi in all four tires. If that eliminates the shimmy, drop tire pressure in one tire at a time until shimmy comes back. That will indentify the bad tire.
Now I don't feel so bad since there are a few others with this issue.
I have had a slight shimmy right at 52mph since I got her 3 yrs ago. And like Edward, smooth as silk everywhere else (especially over 100). I've gone through three different tires, been balanced twice. It does seem a little more pronounced when SLOWING to 50-55 (not braking) than speeding up past 50-55.
I've just chosen to live with it but I sure would like it to go away.
Guess I'll check the control arm bushings next.
Yessir!
My money is on the bushings. I changed them and it is smooth as silk.
As noted above, if smooth just below that speed very unlikely to be wheel imbalance, would bet dimes to donuts it's the control arm bushings. My current 993 and the last one both had the symptoms you describe. Installed Chris' bushings and bingo, all is right with the world.
Agreed! The most common cause at 50-55mph is the control arm bushings.
Heavier wheels or poorly worn tires can mask it a bit so if you change wheels/tires and it appears, you can be tricked into thinking it is tire balance.
My $$ is on control arm bushings.
