vAriOram finish restoration. vram cleaning
After several trials and error, found my combination for the varioram aspect refurbish
The varioram has to be dismantled inside out, pivoting tube extensions as well.
If DIY needed for inside, let me know.
First sandblasting with corindon (aluminum oxide)
and then angle glass bead blasted with 180-300 microns beads, maximum pressure 5 bar
As you bead blast, the shine comes as if you are painting the v-ram, funny feeling
pictures are from mobile phone, but better than no pictures.
left right pictures are of course right= sandblasted, left bead blasted
Have you considered polishing the lettering? I have see that before and really like it.
edit:
https://rennlist.com/forums/993-foru...ram-bling.html
edit:
Seared
RL Technical Advisor
JMHO, but if anyone contemplates doing this, I'd strongly recommend using a soda blaster instead of anything with glass beads or aluminum oxide.
You would never believe where all that hard media get lodged and the consequences are expensive.
BTDT,...
BTDT,...
