New C2 Owner and Rennlister
Thanks for all the positive feedback. Yes it is a Holt's car. And it is missing the fog lights in the turbo s bumper (the second project to work on...get to run searches on all the options you have put in your cars)
The pics are how I picked up the car. Are the exhaust tips really swapped?
I'll have to look at more pics.
Neal
Neal
For starters, take a look under the rubber trim at the bottom edge of the rear window. The rubber seal should be soft when lifted at the outer edge. The rubber seal presses into a plastic channel that is part of the back window and can be pulled away repeatedly. The rubber seal then presses back into that plastic channel. It'll be obvious when you lift it off.
You might brush some LPS 3 rust inhibitor into that area or any other water repellent that is compatible with rubber.
Neal - would you mind sharing what you paid? I am also looking for similar and have corresponded with Holt and would be nice to know what he'll trade for. I was told that the higher milage versions (60k) fetch low 30's. A lower milage car like yours higher. Any thoughts?
