Clutch failure
So here are pics of my exploded clutch. Clearly it failed. Question is why. Any input is appreciated. 95 993 lightweight flywheel. Clutch has lots of material left. Two rivots popped.
I dropped the engine and took the trans mission to have it gone through. Only real problem was getting into second. I don't think the clutch was the entire problem as my syncros were bad. Anyway, I took the clutch apart just to see if the rear main was okay while I had it out of the car. Seal was good but clutch, not so much. I am going to go pick up the box from Mr. Copan tomorrow but will need to order a new clutch before I can start putting it back together.
I noticed that and the place around the edge that was ground down. I think the rivots went and then the center went askew? The second and third pictures show the defect. I am going to show it to Brian Copan today when I pick up my gearbox to see what he thinks. It's hard to diagnose from pictures sometimes.
