A few beers and 3 lifters later..
HELP!
I replaced the passenger side exhaust lifters today and upon startup there is a clanking sound (kind of like a pan being tapped with a wooden spoon). I soaked the new lifters in oil overnight and was expecting some clicking, but this just seems to be a lot louder than I was expecting, and also seemed louder near from the engine bay than underneath the engine. I didn't leave it running for more than a minute or two out of fear I messed something up...
Does this sound normal, or should I take apart to check?
Thanks!
Thanks!
I prefilled mine and it sounded like all hell was breaking loose in the engine when I started it. I shut it down after a minute, then read some old posts and decided to take it for a short drive. As soon as I got to 3000 rpm under load it stopped clacking and has been perfect ever since.
I run 20W 50 and it was pretty cool then so I figured that had something to do with it.
Went for a very short drive (3-5 min) and the noise settled down at idle, but with some throttle it still sounds pretty bad. I would almost equate it to a screw banging around the intake manifold--there doesn't seem to be noise coming from down near that cover...
During the drive there was a slight bogging at around 2k rpm, and the idle got a little on the low-side. Maybe something got messed up when lifting the car from the engine base?
So is the consensus that a slightly longer drive is needed, or should I disassemble and take another look at things?
- this noise is on the left bank. I've noticed it as well on my car (before and after all left's 6 lifters done) and two other 993, so it seems that a slight clanging noise is normal on that side.
- this noise is very ugly and/or on the right side. When you install the rockers you must check carefully that the contact point cam/lifter is in the right position. Actually it's possible that the lifter contact surface is 'turned' upside down when you put the rocker and therefore the contact may be really bad...
Be very very careful with the screw that hold the exhaust bracket, very easy to strip the head, and you may also meet this issue of aluminium and steel welded together (ask me how I know), so better put some anti-seize on the thread...
Two possiblities:
Finally was able to get back to the car tonight... I would not recommend this shop to anyone
--the bolts for the lifter arm were not properly tightened, which caused the commotion. Got them squared away and within 3 minutes of drive the gentle tapping was gone (and the original banging was never heard again!).
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
the good news is that this won't usually cause any damage
glad it was solved!
