DIY: Window height adjustment
I posted about problems with my 993s driver side window on my cab. The window would roll up a bit too high and the window would hang up on the top. If I would shut the door hard enough the window would "pop" in place. Over time the window was starting to damage to the seal on the top.
I found a few older posts but found no answers. I decided to pull the door panels off and I found an adjustment on the window's rail. Here is a link to removing a the door panels:
http://p-car.com/diy/ard/
After removing the door panels I peeled the plastic back and exposed the interior of the door.
I put the window down a few inches and exposed a silver slider with a allen head nut in the center. The slider is adjustable and is what stops the window at full extension. I adjusted the slider and it corrected the problem!
Thank's for the effort and time you put into documenting this. very cool.
