Front Rotor Hats
Well, I've got an early offset 944. I have a set of 993TT front brakes. I measured them and verified that they are indeed 993TT (332mm x 32mm rotors with calipers to match). To adapt these to the 944, I need to change out the existing rotor hat. Lindsey Racing carries a rotor hat for the early offset 951, however, on their website (which I'm not sure if it's just a typo...) it says that the rotor hat is "for Zimmermann 993TT 12.5" cross drilled 2 piece rotors." I don't know of any 993's having 12.5" rotors... I called and left a message but I wasn't sure if they would know the answer, so I thought I'd ask on here in the mean time. I guess worst case would be I order them, see if they work, and if not return them.
http://www.lindseyracing.com/LR/Pors...-86-BBHAT.html
I probably have the hats you need as I'm looking to go the other direction (993 TT brakes from a 944 race car to 993). I have Kokeln Rotor Hats for the 944 turbo.
http://www.vintage911.com/porsche/944turbo-race.html
87 is late offset... I need an '86 early offset... Thanks though (and beautiful car btw!)
I may have to get a local machine shop to make a custom set if Lindsey Racing's doesn't work. We'll see come Monday.
