BLEEDING CLUTCH
Need some help from fellow rennlister's:
I was using a power bleeder to bleed my clutch, and when i open the bleeder valve i get lots of air coming thru. I have fluid in the res, and i put fluid in the bleeder.
The car is not flat, which i believe is causing the fluid to tilt towards the front and causing the air to pass.
Also the pedal drops to the floor, which i believe is a result of no fluid.
Can someone also tell me where i can get a new bleeder valve?
Thanks!
Thanks!
