Problem with new Konis
No, cause even over a bump the spring will not be un-weighted…the shock will never rebound fast enough.
I'll be doing the Bilstein/MO30 upgrade on my new coupe in a couple of weeks.
So the springs may be loose when in the shock by itself, but once it is mounted in the car, the suspension due to its own limits compress the shock and reduce its overall length. Do I understand that correctly. Edited to add: thinking about it, that does not make sense. Usually the shock rod is the length limiter...undo a shock and the control arm will drop further. Would the Porsche have a control arm "stop"?
Let us know or PM me to let me as to how that works out. I am a bit concerned since my OEM shocks I now have and which ill need replacement one day, are stiff enough for me. Fifteen minutes on some bumpy backroads is about as much as I can stand. I won't be tracking the car.
http://www.youtube.com/watch?v=QOKhNS0UYR8
ZP44
Gotcha!
