RS rear side sections ?
I'm planning on installing the Rennline Solid Sides but have already lowered the car to RS height (and corner balanced) and have installed EVO uprights. If I now install the solid sides, which as you say will lower the car even further, am I going to have an issue? Will I need to GEO the car again?
As long as you use 10ET65 and 265/35 or 280/30 tires there should be no issue there. Guys that use 10 ET56 will have an issue
