I just added another diagram. The second pressure relief valve is next to the large oil line fitting.
I wonder what each pressure relief valve is for. Normally, there is only one on an engine.
the 993 oil pump is a dual stage superposed (over/under) pump.
High pressure stage, piston jets, bearings, etc
low pressure, cooling and return.
So two pressure relief valves
Both relief valve pistons seat in the pump core
one releases above 5 bar, and other above 9
regards
