Need Help with Part Number - Sunroof
Does anyone know the Part number/Name of the small black trapezoidal thing that flips up when the sunroof opens. It's toward the front of the car and is about 3 inches across. It has metal pins on either side.
I have the plastic piece and the small springs but one of the metal pins broke off. Any suggestions on a fix or replacement of the pin or the whole thing? Does that metal pin run the length of the part or are there separate pins on either side?
1995 993
Best Regards, Peter
1995 993
Best Regards, Peter
No, close though. Those are the rails for the side. This is in the middle and appears only when the sunroof is open.
I believe its purpose is to guide the wind deflector down and into place as the sunroof closes. I didn't see it anywhere on the Pelican site.
I will post a picture when I get home from work.
Thanks, Peter
Thanks, Peter
Here's the direct link to the Porsche catalog to look for parts:
http://www.porsche.com/all/media/pdf...SA_KATALOG.pdf
Looks like its all one piece... page 323:
964.564.005.01 air deflector
I see my problem now. It is the middle piece of part 21 (air deflector). I may have to fashion something myself - I don't want/need the whole thing. Too bad..
Thanks for the help tho-
Regards, Peter
Regards, Peter
Don't mean to hijack the thread, but I'm in the middle of a 993 sunroof repair for a broken cable. Should I replace both cables or save the $126 and just replace the broken one? Thanks
Item #23. diagram. Passenger side. I found a couple of threads about this part, seems it's prone... It looks like it might be less expensive than a 48cent stamp though.... But i can't use my sunroof until i fix the bloody thing....
To avoid confusion, here is a picture of the part. Notice the pin on the right is broken off. I may be able to locate the pin itself - any ideas. It is one inch long and maybe 1 MM wide.
Peter
Peter
No part #21 is the entire sunroof wind deflector assembly. I carry part #23 which is the sunroof wind deflector hinge (2 Per Car) Part # 911 564 127 00
Hope this helps.
Thanks!
