Check Valve question
My first question is, what is "regular" replacement? How often and how difficult and costly is this? Second, is there an update on whether or not the Check Valve causes the SAI issue or worn valve guides?
Best regards,
Don
I suspect the consensus opinion is that the SAI clogging can be caused by both/either bad check valve or worn valve guides. If you think about it, either could logically lead to this problem. The point is that neither has been ruled out as a culprit.
With a bad check valve, exhaust gases (high pressure) can travel back through the heads through the SAI blower then into the air filter box (at a vacuum). I've always suspected this is the main culprit, but that's just speculation.
