993 aerodynamics
interesting pattern of streamlines on my 993 after driving some hours in heavy rain! Any aerodynamicist care to comment?
Attachment 418108
Attachment 418109
Attachment 418110
Attachment 418108
Attachment 418109
Attachment 418110
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Airflow attached as far as I can see, a good thing!!
I have a similar shot of the front of my car showing how the smallest things (hood badge) disrupt airflow.
Cool shots!
We do similar work on our racecars with a fluid called flow-vis
Cool shots!
![](http://i243.photobucket.com/albums/ff169/rennsport751/IMG_3486.jpg)
What is nice to see is the lines are long and straight. It indicates the air flow is staying attached to the body and flowing smoothly over it. Looks like it was a long steady drive that allowd the lines to form and dry before becoming obliterated. Air will flow around the edge of the wing becuase there is higher pressure on the top than the bottom. There are no lines at the base of the wing becuase it is a low pressure dead spot of stagnant air.
You can see how the adge causes the flow tocurl around the top of it causing a low pressure spot, and then the flow separates and you don't see any lines behind it.
