Winter maintenance
The car is running and No oil leaks.
Here is the list:
New lower valve cover gaskets
New grommets for timing chain
fuel filter
new droplinks
powder coated rear sway
Trimmed up and painted the manifold
Cruise control and SAI REMOVED
bleed clutch slave
Air filter and cleaded ISV.
Here is the list:
fuel filter
new droplinks
bleed clutch slave
Nice work Kevin, most of those items are on my winter list, however its been too cold in my gararge to work (no heat).
Did you weigh the parts taken off? I am interested in the weights of the A/C items as well as the SAI and Cruise....
Keep up the good work.
Steve
The weights include: Cruise 3 lbs, SAI 7 LBS, and the A/C stuff up front 18.5 LBS.
The compressor in the back for the a/c was a TANK.
More pictures
Manifolds cleaned of tabs. Before sanding and painting.
More pictures
A/C compressor is approximately 25 LBs.
I'm not 100 percent sure. It has been years since I removed that.
A/C stuff in the left drivers side wheel well was 18.5 LBs
last picture
last picture
