993 Forum 1995-1998
Suspension Advice - H&R Springs/Bilstein HD (Yes, I've searched...)
Old 01-30-2010 | 10:51 AM
e9stibi's Avatar
e9stibi
For learning the car with this setup is good enough. You can upgrade to PSS10 (or even "better") the next season.
Old 01-30-2010 | 11:54 AM
Van1's Avatar
Van1
Originally Posted by ZombiePorsche44
Ian,
The one thing I forgot to mention is you cannot get 2 1/2 deg neg camber with the stock rear upper mounts, hence my decision to install ERP billet uppers so I can go past 1 3/4 neg deg maximum factory for a combo set up at 2 1/2 neg deg or go to over 3 deg neg if I want a full track set up.
The other benefit is it really ties the top of the rear suspension to the chassis much better than the stock set up.
Joel
Are you talking about the rear upper shock mounts? Those have no effect on camber. Also, I am at -3.1 in the rear with PSS10s set at 10mm below RoW Sport, all else stock.
Old 01-30-2010 | 02:58 PM
ZombiePorsche44's Avatar
ZombiePorsche44
All I can tell you is what Jae Lee, owner of Mirage International, told me about my car when he was setting it up in 07'.
He stated that with my OEM upper shock mounts and the new suspension parts installed, he could not get my rear suspension to go more than 1 3/4 deg neg so I bought rear ERP billet upper's which are fully adjustable camber plates allowing for full range of camber and the additional benefit of being stiffer/stronger than the OEM mounts.
It works for me and I am glad your's works for you.
Cheers,
Joel
Old 01-30-2010 | 04:05 PM
Martin S.'s Avatar
Martin S.
You can go to the Bilstein web site and they quote prices on rebuilds...costs are very reasonable, and there is expedited service available if you are willing to pay a bit more.
Old 01-30-2010 | 08:36 PM
MrBonus's Avatar
MrBonus
Good to know! Thanks, Martin. Also, thanks for all of your input Joel and everyone else.
I officially own the car now. I bought it from Rennlister UserA this afternoon as we drove around in a pounding snow storm to find a notary. It's sitting at the shop waiting for RS sway bars and drop links and a fresh corner balancing and alignment.
I'm absolutely stoked; one of 3714 worldwide and my dream car, ALL MINE. MINE. Let's hope I don't put it into a tire wall.
Old 01-30-2010 | 09:22 PM
ZombiePorsche44
I truly hope that doesn't happen either
Congrats, have fun, be safe....Joel
Old 02-01-2010 | 10:17 AM
MrBonus's Avatar
MrBonus
Just go drive the car. See how it works for you. If it rolls to much, you probably need sway bars. I agree with Steve Weiner:
1. Go M030 RoW, 22mm front, 993 TT M030 RoW rear 21 mm (pretty cheap)
2. 993 RS bars, 23mm front, 20mm rear, adjustable, 5 way front, 3 way rear.
I have the TRG 25mm front and 22mm rear, the front is too bloody stiff...I can only run it at full soft.
There are lots of track guys running Bilstein HD and H&R. It may not be the super trick set up, but it works.
With all the money you have saved consider doing this:
1. Get a G2X or Traqmate
2. Get some good tires
3. Hire a coach
Martin, after lengthy consideration, I'm probably going to drive the car as-is as you've recommended assuming there are no clearance issues with the HD drop links after it is raised up a bit. If there is, I'm going to go all-out with the RS bars and links.
Thanks!
Old 02-01-2010 | 12:35 PM
Martin S.'s Avatar
Martin S.
Smile Go get them...
Mr. Bonus aka Ian,
Just get out there...and when you make a change to the car, make one at a time so you can measure the performance increase, or decrease as the case may be. If you don't have significant seat time, you wont be able to push the car to the level where the changes(s) will become apparent. Go for it, drive it like you stole it! Good luck and welcome to the Club!
Old 02-01-2010 | 12:48 PM
MrBonus's Avatar
MrBonus
Mr. Bonus aka Ian,
Haha, thanks. I run Advanced but rose through the ranks with an Evo which is a vastly easier car to drive fast. I agree with everything you're saying and want to first begin to approach the limits with the car before I make changes.
My only concerns are that the current suspension might have deficiencies related to geometry that may cause me mechanical issues like end links breaking prematurely or other suspension wear. I want these issues rectified prior to doing my first event in spring.
Thanks again, Martin!
Old 02-01-2010 | 04:27 PM
fast_freddy's Avatar
fast_freddy
I have a HD/H&R setup, with RS links and Turbo Sways at RS height and it works quite well. The car is quite neutral (225F, 265R on 18's) and quite nimble. Frankly I am quite pleased with it. I am contemplating going with PSS10's this spring as I'm doing the RS front carriers, Rennline adjustable camber plates and three point strut brace. The only reason I'm doing the PSS10's is that I figure I'm doing the other upgrades so I might as well... Whether I "need" it or not is a whole other story.
Old 02-01-2010 | 06:08 PM
MrBonus's Avatar
MrBonus
Interesting. Are the RS links a must for this setup?
Old 02-01-2010 | 06:42 PM
Paddy's Avatar
Paddy
It doesn't really matter which drop links you have installed if they're installed correctly. If i remember correctly the H&R springs are close to RS ride height. You might want to consider installing the RS drop links as this drops the bar below a-arm. If the bar is above the arm and your suspension gets completely compressed it may rub on the a-arm and cause problems. I had my RS sway bar shear off at VIR when I was running a H&R setup.
Bar with RS links-
Old 02-01-2010 | 06:45 PM
MrBonus's Avatar
MrBonus
Patfat, funny you post this here because it was your thread about this exact topic that prompted my question. I was hoping that the short drop links supplied with the HD shocks would be enough to provide clearance but that doesn't appear to be the case...
Old 02-01-2010 | 06:50 PM
Paddy's Avatar
Paddy
Ian, I'm still not sure that was what caused the bar to break, but it seems the most logical. In the end the RS drop links are cheaper than a RS sway bar...
Cheers, Patrick
Old 02-01-2010 | 07:22 PM
UserA's Avatar
UserA
ALL MINE. MINE.
Go to Hell Ian!
