Any one know the trick to separate the gas pedal...
07-05-2010, 08:58 AM
Quote:
Originally Posted by
Quadcammer
I've found it easier to just unscrew the rod from the linkage and just mark how many threads of engagement you have to keep adjustment the same.
Thanks. I'm pretty sure that the pop-off method is ten times faster despite being less graceful.
07-05-2010, 10:57 AM
Mark in Baltimore
To get it off, sure.
It put it back on? good luck getting the ball to seat into the cup. Thats the big PITA.
07-05-2010, 11:38 AM
Quadcammer
Ken's post taught me that all you need is a pair of Vise Grips to hold the linkage in place. I snapped the ball into the cup in two seconds.
race911
Or use Vise Grips against the floorboard to keep the rod from retracting when you apply pressure to the pedal to reattach.
07-05-2010, 11:51 AM
Mark in Baltimore
+1. I put a little WD40 on the ball which also helped "pop" it on.
993 ,
ball ,
bill ,
factory ,
gas ,
install ,
linkage ,
pedal ,
pedals ,
rennline ,
skull ,
socket ,
trick
