993 Forum 1995-1998
Exhaust Clamp Bolt
Old Dec 16, 2009 | 05:12 PM
Bill Verburg's Avatar
Bill Verburg
25 Year Member
Originally Posted by FisterD
It won't gall as stainless can in any application, but the factory hardware definitely corrodes. I have worked on a lot of exhausts, and many are so corroded the bolts will break or have to be cut off due to the corrosion.
Stainless will work fine for the exhaust, but as Bob noted, use some anti-seize on the threads.
I suppose anything can corrode but here's a pic of oem silicon-bronze exhaust clamps & bolts that have been in service for over 10 yrs, including lots of salted roads. Not a spec of corrosion anywhere.
Incidentally all of the oem exhaust hardware is hardened, something that can't be done w/ ss.
It's your car....
Old Dec 16, 2009 | 05:22 PM
AOW162435's Avatar
AOW162435
Seared
And I thought all along that the nice Aeroquip (UK) clamps on our exhaust system were stainless.
Andreas
Old Dec 16, 2009 | 05:31 PM
TheOtherEric's Avatar
TheOtherEric
I don't think the OEM bolts are ss, somebody correct me if I'm wrong. Nothing wrong with just picking up some 5/16" bolts from Home Depot and using some anti-seize. These are just exhaust tip bolts, guys. Save your money for something useful.
Old Dec 16, 2009 | 05:55 PM
Bill Verburg
25 Year Member
Andreas
no they are not, as I said I don't know the alloy but they look like the silicon-bronze alloys we use in marine applications. They are harder(bolts are 8.8) and more corrosion resistant than any ss alloy.
As I said I could car less what you do w/ your car. But at least be aware of the issues. If saving a few pennies is that important by all means scrooge away.
Old Dec 16, 2009 | 06:03 PM
boulderbobo's Avatar
boulderbobo
VVVVVV ME VVVVVV
File Type: jpg
Old Dec 16, 2009 | 06:10 PM
AOW162435's Avatar
AOW162435
Seared
I presume that's directed at someone else?
Andreas
Old Dec 16, 2009 | 06:20 PM
pcarhombre's Avatar
pcarhombre
I think that was directed at me Andreas, but don't know why. I never indicated I was trying to save money on the bolts, just trying to find out what they were and where to get them other than the dealer. And happy holidays to you, too, Bill.
Old Dec 16, 2009 | 06:44 PM
Bill Verburg
25 Year Member
Andreas
It wasn't directed at anyone in particular, sheesh you guys are sensitive,
Old Dec 16, 2009 | 06:48 PM
Bill Verburg
25 Year Member
and the answer was provided in post #7, the issue became muddled by alternate responses. I honestly don't find the discount dealers prices for hardware to be out of line w/ quality alternative sources like McMaster Carr or other similar vendors.
The oem hardware is remarkably well designed and implemented.
Old Dec 16, 2009 | 07:47 PM
FisterD's Avatar
FisterD
Wow, Bill, your hardware looks remarkably good. This is generally what I see with all of the exhausts I r&r.....
File Type: jpg
Old Dec 16, 2009 | 08:31 PM
boulderbobo
^^^^Mine looked just like that^^^^
Old Dec 16, 2009 | 08:36 PM
tjangi's Avatar
tjangi
I wan't my Stage 2's back
Old Dec 16, 2009 | 08:42 PM
jscott82's Avatar
jscott82
Im with bill on this one... They are stronger and harder than any SS I have seen. If SS would do the trick I'm sure Porsche would have gone that route rather than whatever special alloy they used.
When I got my car it had some cobbled together supertrapp exhaust. I had to replace the whole thing. I got all the nuts and bolts from DC Automotive for like $20. Threw them in the tumbler for an hour and they look/work like new.
Just my 2 cents...
Old Dec 16, 2009 | 09:04 PM
AOW162435's Avatar
AOW162435
Seared
Can I send some stuff to get tumbled?
Andreas
Old Dec 16, 2009 | 09:58 PM
MarkD's Avatar
MarkD
I suspect Porsche didn't use SS because it can weld itself to itself... using SS nuts and bolts requires another step to maintain them. They would have to train Porsche Techs to use anti seize on exhaust clamp bolts. If the Techs did not use it they would quickly have many broken bolts on their hands and increased cost.
The bolts don't need to be hardened for this application.
Cost isn't really a factor either since neither are terribly expensive.
Buy the bolt that floats your boat
Much ado about bolts, eh?
