home garage lifts
Look for reviews, do your research, and remember you are buying a device that puts several thousand pounds over your head...so be safe.
Not sure what you mean by "5 ton nominal capacity", you mean 10,000lbs? that is a pretty large lift, sounds great. Take a look at the video I posted about the stress test on a 10,000 lbs lift that had a major failure.
Cheers,
Mike
Cheers,
Mike
Yowza! I just watched that video mike, and its scary.
I actually got the TP-10 (which is like the TP-9, only it was 10,000 rated and had a lifetime warranty). I liked the idea of lifetime warranty, but perhaps if you cheap out on your lift the warranty and your life will end at the same time
p.s. It looks like they were not centering the load in that test -- I always work extra hard to get what I feel the 993 cg is toward the center of the lift arms.
-reiner
-reiner
Yeah, I agree, I think it was an unfair test in that it really loaded one side of the lift. That can a happen with vehicles, but not that bad. I am the same as you, I tend to try to put the 993 on the lift centered to the weight as best as possible. Hard to really tell how well its balanced though..
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
