993 heat stuck on drivers side
Just bought a 1995 C2 with 48,000 miles, all is perfect except the drivers side heat is stuck on. Passenger side seems to do what it should. Where do I start?
Congrats! You get to replace the servo motor on the drivers side footwell
I'll go lookup a part # for you...
I had both go bad in back to back months. I let them be until summer :-)
-reiner
-reiner
The flap is right above the dead pedal, once you remove the trim on that side. Be careful with the flexible yellowish hose that attaches to it, as it can be fragile. Its a bit easier to see in the parts diagram (pelicanparts.com will show you it if you click on the right tab).
Also, be sure to call sunset to check prices there and FD motorsport too
-reiner
-reiner
-reiner
-reiner
As others have said, you can sometimes free up the flapper valve and give it a little lubrication.
Congrats on the 993 purchase!
Thanks guys, got home late and tomorrow is the big eat so I will work on it Friday (should put up the xmas lights) and will post the outcome. Thanks again, I better become a member.
Problem solved. I took the flapper valve out and just moving it fixed it. By the time I could see the flapper itself it was already moving. Thanks for the help.
