SAI signal simulator
Update:
I could not find the appropriate fuse or relay for the SAI air-pump - so I just wiggled my hand in - and disconnected the electrical connection which is that long wire to the left of the air-pump itself - just above the distributors.
Sure enuf - when I did 'ignition on' - the air pump did NOT come on. So far so good.
I had my OBD-ii reader connected and took a looksee at the voltages of the (downstream) O2 sensors. Dahyum -- both showed .45V -- so, for all practical purposes there appears to be no 'obvious' difference (ignition on / engine off) inasfar as the O2 sensors are concerned - if the pump is running or not.
Oh well, back to the drawing board...
G.
G.
Cheers,
MIke
I might have some input here.
I plugged in my OBD-ii reader and turned on the ignition - but didn't start the engine. Of course I could then hear the air pump puffing away to its heart's content.
Both downstream O2 sensors were showing 0.45 V -- which is the normal signal that you get when both catastrophic converters are 'working efficiently'. If both cats are 'bad' or there is a problem with the gasses that are blowing by -- these downstream O2 sensors usually start showing a HIGHER voltage, e.g. .8 to .9V
Well, now that my NY inspection is a thing of the past (i.e. last Sept. - so now I'm not too worried if I trip a CEL) -- my next trick will be to remove the relay that controls the SAI pump - disabling it from running -- and seeing if that has any effect on the voltages of the two downstream O2 sensors.
Stand by, as they say.
Gerry
Gerry
Working on it....having a bitch of a time getting the connectors I want, but I am making slow progress. This is turning out to be more of a waiting game than I anticipated...I am missing one key part, and am waiting for an ETA from the manufacturer in Europe since they have to do a manufacturing run. This is what happens when you are dealing with a 12+ year old car.
I am sorry for the long wait but there is only one path to getting these parts officially.....so unless I decide to circumvent (and violate a whole bunch of copyrights, etc.) I have to wait.
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
Cheers,
Mike
Agent Orange
Thanks for the update Mike! Personally I'm in no rush, just thought that you had a great idea and would like to get one of those kits before P1411 strikes ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Thanks again,
Ilko
Thanks again,
Ilko
Technical Guru
Almost have the parts for the prototyping stage...its been a real challenge. Know what I want to build, but need the parts to get the physical design done. Will turn it over as quickly as possible, and then I need a few guys with this problem to test the solution....I am sure there will be some takers. David is #1 on the list if he can wait.
Cheers,
Mike
Cheers,
Mike
Mike,
I'd love to volunteer as another tester. My 96 has had these problems for years; I flush and clean to pass emissions, only to hace the dreaded CEL come back.
regards,
Michael
regards,
Michael
