HELP - CDR-220 with i-Pod Connector
i-Pod charging right now and will attempt to download the playlist today. I have to leave or Nashville, TN so may not get it done. I think I have everything I need to make it hapen. Famous last words.
Mike
Mike
What faceplate change are you talking about? Is it just the European faceplate or is there now a way to display the ipod info on a new faceplate? I bought my CDR-220 from that stereo place that advertises in the Panorama and got the orange Euro faceplate and a cable that charges the ipod. I love how it fits perfectly in the ashtray when you remove the actual ashtray from the compartment.
The original faceplate angle is not designed for the 993. What happens in the daytime is you can't see the display. So you have to send it to Becker for the reverse colors on the faceplate. There is no change in the faceplate except the colors are reversed. As far as putting the i-Pod in the ashtray that is a great idea and I tried doing the same, but with the connector and the i-pod (Nano Gen 5) it was 1/4" too big. I am going the glovebox route since it can be locked as well. You may have the smaller version i-Pod.
EDIT: i-Pod is only controlled from the i-Pod not the stereo
Mike
Mike
I picked up a replacement CDR-220 from RL'er TxnBluDvl, sent off the faceplate and ordered the new style Ipod cable (does not work w/ Ipod Touchs though), when I installed it the 220 would not recognize the Ipod. Remembered this thread, followed "ezinternet's" instructions and now the Ipod plays. Thanks again.
It does work with the Ipod Touch. I initially had the same problem. But it works fine now...I'm certain a search will help you...can't remember now, but it was a simple programming issue...pushed a couple of buttons and bingo...all is good.
Lifetime Member
Lifetime Member
Only advise I can give is to make sure you get the ipod connector with the powder wire, this way you can connect the ipod and charge it at the same time
Edit: Here's the new cable Becker Ipod Cable
Why do I feel so left out!
Whats a stereo ?
Whats an ipod?
Simon.
Whats an ipod?
Simon.
