Rear Brake Flush, found plugged lines!
Hey Listers,
I just had my brakes flushed at the Porsche dealer, they told me that they were partly plugged, and it took a lot of flushes to clear the rear brake lines. No wonder they felt mushy!
I bought the 993C2S last March, could not find any record of a brake fluid change, maybe it was included in the 30K maintenance schedule?
So a note of caution to all... get that old fluid out of there!!!
Now there's a nice winter project :-)
Cheers,
Bert
Cheers,
Bert
I don't know exactly why or what it is, but a waxy substance builds up in the brake system, and I've seen it pretty much clog the bleed nipples, so much I had to remove them to get any fluid to bleed out, even with plenty of pressure in the bleeder. I can imagine what it must do to the ABS controller...
I have seen the waxy substance build up as well. I recently had the brake reservoir replaced because of the amount of the buildup. I have yet to find a reasonable explanation, but it is a potential pita simple because of the damage potential.
Cheers
Cheers
My passenger inner rear was plugged. The power bleeder did not work at all on that one.
I eventually had to get a friend to press the brake pedal, and with enough pressure the gunk came right out.
From the p-car manual:
Important information about the brake fluid
Use only new brake fluid DOT 4.
Observe brake fluid quality.
The brake fluid DOT 4 Type 200 (change interval 3 years) used until now is no longer available via the Porsche Parts Service.
"Super DOT 4" brake fluid will be delivered instead. A 2-year change interval applies to this brake fluid.
Vehicles with brake systems containing the old type of brake fluid must be filled with Super DOT 4 the next time a brake fluid change is due.
This brake fluid is available under the following part number;
Container size 1 litre = 000.043.203.66
Container size 30 litres = 000.043.203.67
Miscibility of brake fluids:
The brake fluid DOT 4 Type 200 used until now is miscible with Super DOT 4. this means that Super DOT 4 can be used to top up the brake fluid-level in vehicles with brake systems containing the old type of brake fluid until the next time a brake fluid change is due. Both brake fluids are coloured amber.
