Need Help with 993 assembly.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I'm looking... I did find the headlight drains and operation.... the wiring diagram I thought was .. isn't... hold on this is pissing me off
It's a great book, problem is it jumps around and the book is thick!
ok,
this book, show the operation and adjustments of the headlights, wipers in GREAT detail, why no wiring for this?
Are there any numbers on the wiring housing or where they mount to?
I am trying here, usually I can find anything.
I looked through every chapter. Maybe you found the weak link of the book.
993 Companion....
I'll look on the Pelican site, too. I'll post it if noone else does before me.
993 Companion....
Thanks. I looked on pelican for hours diagrams, forums and nothing.
Im just here to test your knowledge. lol.
no but seriously I do need the wiring info. I will keep looking too.
If someone with a 993 would come forward and just open there hood (Bonnet) undo the center plastic mount that is on the drivers side and pull on a pair of the wires just to find out which is which would do the job.
Are you kidding me? This book wore me out...
Table of contents is a mess. It gives page numbers such as...
Electrical: 26,27, 96, 102,247, 249, 250 352, 378,
should say: you're screwed without a part #
Anyways, looks like it's tomorrow. My brother would know in 2 seconds.
I'll check your thread and help if you haven't found your answer.
Peace,
Craig
Peace,
Craig
