FS - AN Lines and fittings for second oil cooler install - Sold
Based on the following post on Pelican (http://forums.pelicanparts.com/porsc...rs-93-rsa.html) I bought all the requisite AN adapters, fittings and lines to do a second cooler install, but the way I have my brake ducts routed would have caused rubbing so I ended up buying the ERP kit instead…. (I’ll post the details of the oil cooler and brake duct installs in a separate thread if anyone is interested). So I now have the following pieces left over:
1- Male 30 x 1.5mm Metric Concave Seat to 12AN, Aluminum
3- Female 30 x 1.5mm Metric Convex Seat to 12AN, Aluminum
2- 180' Aluminum #12 Hose End / 12AN
1- 150' Aluminum #12 Hose End / 12AN
1- Straight Alum. #12 Hose End / 12AN
18 feet - #12 Size Stainless Steel Braided Racing Hose
Total Cost was $370, I'd like to get $200 for all of it, but will entertain lower offers as I have no use for them at this point…
Jeff
Jeff
Jeff, Be sure to pay particular attention to thow the second cooler is shrouded. It is imperative to duct all of the incoming air through the cooler for maximum effectiveness. Good luck, Jerry
BTW: we met a couple of years ago, you were down here at CMP with Mark and Spencer doing testing. It was a plesure meeting you...
