What's on your winter to do list?
I haven't seen this years standard post yet so I'll start. I apologize if I just missed it!
Now that I'm about to take the car off the road 'til spring I started thinking about my winter to do list. Last years work included new suspension, sways and control arm bushings so I'm going to take it easy this year. I know I can't keep up with some of you guys. I've got my latest Mopar project going too.
* std oil and filter change
* inspect suspension front and rear
* bleed brakes
* recover Rod Birch subs (ordered wrong carpet)
* fix sunvisor that keeps popping out
* fix rattling sunroof (when open)
* drop tranny and figure out why it hangs up when decelerating/replace RMS/clean and regrease splines. I'm guessing that I will likely have to replace the whole works. At least the new 4 post lift will make this a little less cumbersome. I hope I don't regret just dropping the whole works.
* Inspect and change distributor drive belt and perhaps the power steering belt. I don't know if these have ever been done (70k)
* touch up rock chips
That will do it for now!
* bleed brakes
Oh, original thread:
Clear bra
Front rotors
Paint calipers
Commit on the interior color / seats (long story)
Oil change
Brake fluid change
Short shift kit
Find inexpensive Gemballa Competition rims
Clear bra
Front rotors
Paint calipers
Oil change
Brake fluid change
Short shift kit
I hope so too, one of the nicest out there imho.
My plans are still a little fuzzy but in the range of possible are:
* plugs
* power steering belt
* clutch
* LWF
* 2WD conversion
* short shift kit
* switch from EVO hub carriers to stock
* billet shift forks / steel synchros
* fix sunroof headliner
* fix Moton line routing
* give the wheel wells and engine compartment a good cleaning
* oil change
* plugs
* clutch
* LWF
* 2WD conversion
* short shift kit
* oil change
Depending on how cold it gets (no heated garage)
- weight reduction: Heater Blower, SAI, Air bag, Stereo, knee pad
- ERP / Tarrett toe, kinematic and camber links
- RS Transmission mount
- Hard Wire Traqmate
- RS rear calipers
- Pads and Rotors all around
- Walrod rear bushings (Come On Chris)
I am sure other stuff will come to mind...... Depends on budget and time.
- RS rear calipers
Last edited by trophy; 10-07-2009 at 07:19 PM. Reason: To add more stuff (Thanks Jeff)
Maybe nothing but normal maintenance this year, unless Mr Walrod introduces his rear suspension bushings.
Normal maintenance is oil/filter change and brake fluid flush each winter.
I have an RS tranny mount sitting on the shelf, but I've been waiting for the clutch to go before I dive in.
Trophy, I hope you post a "how to" documentary when you do yours. I can use the help!
For the 95:
Replace windshield
fix small rust spot at base of windshield
get front bumper repaired/resprayed (stupid road debris!)
replace rear window seal
oil/filter change
brake flush
bumper plugs
For the 97:
oil/filters
plugs
caps/rotors
dist. belt
belts
rotors/pads/ (and eveything associated with) F&R
brake flush
change gearbox oil
replace rear stone guards
bumper plugs
Replace windshield
oil/filter change
brake flush
bumper plugs
For the 97:
oil/filters
plugs
caps/rotors
dist. belt
belts
brake flush
change gearbox oil
bumper plugs
Lexan all around
New headders. Working on some that really make power.
Move as much weight forward as I can.
Re corner balance the car
Get a new set of race wheels.
Re-wire the car and seal off the fire wall up front.
Re paint the roof and rear bumper
Consider fiberglass rear fenders
I race PCA and a local track club. My local raceing class does not limit my weight so I want to add ballast for GT4 and take out weight for my local racing. Its amazing how much faster you are with even a few hundred pounds off the car.
