PowerLift Jacks for Storage
I am thinking about buying a set (4) of these to make winter hibernation a little easier, if I need to move cars around (since I don't run them) in my heated storage facility. Does anyone have any experience with these? Thanks.
http://www.ineedparts.com/tools-and-...hydraulic.html
that is what the repo man uses to move a car before it gets on the tow truck...they work great as long as u are not on a hill .the problem is that with all 4 courners up it could role away.
cheers, nick
cheers, nick
Nick
These are a "take-off" on the original GO-JACKS. In addition to being extremely useful in re-positioning in tight quarters and/or moving w/o starting, they perform an additional feature: Raising a low-slung car in order to get a floor jack under it. Example: With a lowered 993, place the "positioning jacks" under the front wheels and raise them up equally. Using the 2"x6" method across the front pan, raise the front end by putting the floor jack saddle in the center of the board, then place your jack-stands under the proper support points. You can also use the positioning jacks on the rear wheels to raise the rear if clearance is a problem there. Lowering is simply a matter of reversing the procedure.
BTW, using positioning jacks on all four wheels is a scary proposition unless you have a helper. The car is like on roller skates and can have a mind of its own! Using just two is a little more time-consuming but EZ for one person. If your garage deck is on an incline, I wouldn't recommend using them.
