993 Forum 1995-1998
Fuel for your ride...
Old 08-06-2009, 08:26 PM
flyingchappy
flyingchappy's Avatar
Default Fuel for your ride...
I haven't even picked up my first 993 yet and I don't want to feed her with the wrong juice when I do.
What fuel types are you using? Octane? Ethanol or non-ethanol? What does Porsche recommend?
Old 08-06-2009, 08:31 PM
Tom W
Tom W's Avatar
Use only premium unleaded gas. What octane that is depends upon the state you live in, but anything over 91 should be fine. You are unlikely to get a choice of with or without oxygenators (ethanol or otherwise).
Old 08-06-2009, 08:40 PM
flyingchappy
Default corn fed
Thanks, the only reason I asked about blended fuel is because I had run into an issue with ethanol in my ducati. Apparently it deteriorates the plastics in the fuel tank causing a gross distortion in it's shape over time, a very short time. This issue is only in the US since the EU doesn't blend their fuel.
Old 08-06-2009, 08:44 PM
helmet155
helmet155's Avatar
Me likey Chevron with Techron. 91 is the highest we can get here in California. Using (R+M)/2
Old 08-06-2009, 08:57 PM
NC TRACKRAT
NC TRACKRAT's Avatar
Major brand 93 Octane without ethanol (which, BTW, costs more to make than the gasoline it's supposed to save!). BTW, I pass up any station where I see the tanker delivering. They stir up the sediment.
Old 08-06-2009, 09:21 PM
bart1
bart1's Avatar
Around here I can get 93 octane and Philips 66 has non ethanol. I use that or Shell or Chevron.
Old 08-06-2009, 10:49 PM
Cactus
Noodle Jr.
Cactus's Avatar
Just filled up with Citgo 93 Ethanol free the other day. Sounds like the way to go but I'm no expert.
Old 08-06-2009, 11:00 PM
timothymoffat
timothymoffat's Avatar
Chevron 94 here in BC (Canada, eh).
Old 08-07-2009, 12:32 AM
95C4VanIsle
95C4VanIsle's Avatar
Same here but I am not sure about ethanol content and if it is used to boost the octane ratings. Anyone else know? All I know is that it is the highest octane rating I can purchase locally.
Old 08-07-2009, 12:44 AM
Van1
Van1's Avatar
91 is the best that I can get here in Nebraska and seems to work fine. Used to be able to get 92 at BP but they went down to 91. I always say no to corn gas. I have respect for famers but not going to support their lobby.
Old 08-07-2009, 12:45 AM
Cactus
Noodle Jr.
Cactus's Avatar
Someone was just telling me that it will deteriorate rubber seals as well.
Old 08-07-2009, 12:50 AM
AOW162435
Seared
AOW162435's Avatar
JP-5. The car smokes a bit but I think it helps lubricate the fuel injector pintles better than regular fuel.
Andreas
Old 08-07-2009, 04:12 AM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Andreas
JP-8: If its good enough for an SR-71 @ Mach 3.2+, then it oughta be OK for a 993, yes?
PS,....boron cartridge needed for initial start, tho.
Old 08-07-2009, 05:40 AM
J.A.W.S.
J.A.W.S.'s Avatar
super+ 98 or ultimate 100
Old 08-07-2009, 08:56 AM
AOW162435
Seared
AOW162435's Avatar
I buy 'em by the case.
Andreas
Quick Reply: Fuel for your ride...
