Fan Question
#31
IMHO, that should be connected on a 95...where was Andreas' connected?
#32
Seared
Noodle Jr.
So reading the article in The Essential Companion it says the second stage runs continuously. Guess mine has been unhooked since I got the car hopefully not harming anything??? I found a connection that would reach the one in the picture and hooked it up but still nothing.....WTF!?
#34
Seared
Your fan is hooked up (connection to the left of the blower motor), your resistor is in place, and your temp sensor in the blower tube is intact. That disconnected thing controls a vacuum actuator that opens and closes a trap door between those two sections of plastic piping. Something about keeping exhaust fumes out when the car is in reverse and the heat is on.
Or sumpin like that.
Andreas
#35
I think your fan is operating fine. I do wish I knew the logic for the flapper opened/closed.. Andreas is probably correct as usual re: reverse, but I do believe the flapper opens up to provide more fresh air to the top of the juggies while the engine blower is on low or high speed and ignition on.
PS: I miss the juggies from the "Man Show"
#37
Trying to read German auto symbols is not the easiest thing but it appears there is also a blower resistor in the hot circuit to the motor. The temperature sensor we're talking about appears to vary this resistance causing the fan to run at different speeds.
By the way, the engine compartment has to be fairly hot for the temperature sensor to kick the fan on. Mine doesn't run every time I drive the car. Sometimes it takes a few minutes after shutting the car off for the temperature sensor to run the fan.
#38
Cactus - check this pic of Bart1's ride:
![](https://rennlist.com/forums/attachments/993-forum/342192d1236477529-mark-up-another-xenit-fanboy-dsc02029.jpg)
You should pull off your trumpet piece (2 bolts) and maybe you'll find that connector's mate.
If you did find it's mate, check fan operation by key on and rotate temp dial from cold to hot...and note the vacuum actuator position. If it changes you're working.
