9m Racing Varioram Motronic to Non-Varioram + Motec conversion
#31
Geoffrey and I pretty much share the same ideas regarding Motec installations, so anyone in the US who is interested in a package might like to contact him first.
#32
From my own experience the biggest difference in hp was made by advancing the ignition over what the stock mapping allows for...
All else is just fine tuning and while equally important, it does not add to hp count much.
Also, one should not only look at the top figures (hp/torque) but the shape and size of the torque curve. It tells you so much more about the engine.
I got +50Nm troughout the entire powerband with Motec, that is way different from getting for example +80Nm in a very narrow area...
You are absolutely right about the "area under the power curve", it is far more beneficial than a notional peak value.
#34
Originally Posted by joe [email
original@flash.net[/email];9662636]Again I ask will this set up work on cars with obII and 200 cell cats
ie.. 96 and newer?
ie.. 96 and newer?
Also, in order to connect to the 88 pin loom you will need to find a scrap 88 pin ecu from another car to use for the Motec adapter box (because neither myself nor Geoffrey could find the 88 pin AMP ecu male plugs readily available for sale). The OBD2 ecu is not commonly found in Europe, hence all the conversions I have done are on a 55 pin Euro 993 - apart from one in the shop now which is having a full new custom made wiring harness to match a M84 to a throttle body 3.8 engine.
As for previous question about Tiptronic, I think the answer is no. Certainly I have never attempted a Motec conversion on a Tip but in addition to that, I have no desire to attempt one as I could not guarantee to get the expected results.
#35
"From my own experience the biggest difference in hp was made by advancing the ignition over what the stock mapping allows for...
All else is just fine tuning and while equally important, it does not add to hp count much."
So right on for a stock engine!
Read here for some supportive data: https://rennlist.com/forums/911-foru...-the-myth.html
