9m Racing Varioram Motronic to Non-Varioram + Motec conversion
The 9m Motec conversion for the 964 or 993 (OBD 1 only!!) costs £3500 fitted & mapped, this equates to approximately £2750 in parts & the rest in installation, dyno & road mapping time. On more then one occasion I have sold the Motec package as a kit of parts for customers who cannot get the parts locally, in all circumstances I will send a start map pre-programmed into the ecu to get you running, but you will have to get the engine fine tuned to suit local fuel and conditions (or pay me to fly over and map it for you!). Just understand first that whilst there are a lot of so-called Motec tuners out there, only a few of them can get the best from the system.
Yes Joe, the little dip is the crossover point of the resonance flap closed torque curve (low rpm) & flap open curve (high rpm). There's a recent thread on the 964 forum where a chap had the resonance flap removed from his manifold & I have posted a sample dyno curve showing the effect of the flap in both open & closed states if you're interested.
In the case of the results for this engine, I expected it to make 280-290hp on our dyno before the conversion and found that it had a failed coil which would have pulled the power down somewhat, so the actual gain is more likely to be around 30hp as mentioned in the opening post.
Colin -
how does this motec tuning compare to your 9m 993 NVR+2 Conversion ? Ease of set up? Client preference when looking for more reliable HP & TQ? Thanks. One of these days .........
I have a 993 varioram (US Spec). I had (now crashed) a track prepared 993 with Non VR engine (Euro spec, large throttle body, polished intake , Rs cams, higher compression , LWF, retuned and with short gearing etc)
I am seriously considering transplanting the engine and gearbox into my 993 cabrio, but have heard horror tales about wiring loom compatibility between VR and NonVR. Searching this tread, I see Ninemaster has done the work before.
Can you confirm that? if so, would be very interested in any help / solutions you could provide.
many thanks
many thanks
many thanks
many thanks
the 55pin DME's were used on all RoW 993 n/a cars and on US '95 993
to install V-rm on a non vram car
pin#32, yellow/white has to connect to the resonator(which used to be DME pin#1)
DME pin #1(which used to be the resonance flap) grey/white connects to the vram actuators.
all the actuators need the 12v red/white to work
and of course a chip for a RoW vram
The change from non v-ram to v-ram or back is easy as long as you have a 55pin OBD1 DME
The sad truth though is that all these features are built into the Motronic system, but such is the relative complexity/lack of knowledge about the tuning of the software I doubt that you will find anyone willing to invest the time in to getting it right. Isn't it a shame that nobody has written an emulator program for the Motronic which has the look and feel of the Motec software?
So the real answer to your question is that I could not recommend a Motec upgrade on the 993 purely on the basis of performance as the stock system (in theory) will do the same job. Add mechanical upgrades into the pot like the +2 package and the answer is the same. However, when the Motronic requires further tuning beyond the ability of the tuner, a Motec upgrade will have a clear advantage in yielding the potential from the engine.
The clear benefit of utilising the Motec system is the ability to tune everything on the engine. There is more to mapping than the fuel and ignition curve at full throttle, so having the ability to understand and manipulate features like the idle control parameters and fuel trimming from manifold pressure will give a good tuner the clear advantage over Motronic.
Since the original thread was posted Motec have discontinued the M48 and replaced it with the new M84 ecu, essentially a software limited M600. The price of the conversion has thus increased, but the good news is that the M84 comes with datalogging and lambda as standard so we now supply a wide band lambda sensor to make the most of the additional features which were not included in the M48 kit.
RickyG (06-24-2021)
You're not missing anything. The 9m Motec package has allowed us to fully optimise the fuel and ignition maps of the engine live on the dyno, the results being those shown of a non-Varioram equipped engine without cats. No snakeoil, what you see is what we got. I suppose what I am saying is that similar results may be possible with Motronic or other systems, but that is for someone else to prove.
From my own experience the biggest difference in hp was made by advancing the ignition over what the stock mapping allows for...
All else is just fine tuning and while equally important, it does not add to hp count much.
Also, one should not only look at the top figures (hp/torque) but the shape and size of the torque curve. It tells you so much more about the engine.
I got +50Nm troughout the entire powerband with Motec, that is way different from getting for example +80Nm in a very narrow area...
