Rear Bilstein HD droplink problem
Hi,
I have the problem as described in a post by quasr back in 2007 where the droplinks on the rear shocks either separate from the sway bar or the droplink mount on the shock. On mine the droplink is completely missing and I can freely move the droplink mount by hand. See link [URL="http://https://rennlist.com/forums/993-forum/386076-problem-with-bilstein-rear-shock-drop-link.html"] Can someone please tell me where to source the lock rings?
Many thanks
Many thanks
Seared
Andreas
Unfortunately, the lock rings will be nearly impossible to turn ever again. I did this when I first installed my suspension three years ago - when I took it in for the alignment (and slight front ride height adjustment) the tech and I had to carefully pick the dried LoccTite out of the threads.
Andreas
Andreas
