Funky Smell
We've been enjoying warm weather here in the northeast and so this problem has become more pronounced. The car smell funky even when the a/c is not on. (And yes; I've showed in the past thirty day!) The first time I used the a/c this summer, my SO and I almost choked on the noxious fumes that came out. It got better with time, but there is still a strange smell in the cabin even when the a/c is not on. I checked the carpets etc and they show no sign of mold or water damage, so I'm coming to the pit masters to ask what might be the source. TIA!
(Showered) My attempt at humor was mis-spelled.
Never had it from the AC vents in my car but a possible culprit is wet pollen filters. My wifey had this problem in her Mazda. Easy enough to pull them out and sniff them to see if they are the cause.
http://p-car.com/diy/pollen/pollen.htm
I think it is difficult for water to get into them, but maybe with your car sitting they got stinky.
If it's a moldy smell, maybe your evaporator core got funked up from sitting. My buddy has this in his older 911 from sitting for a year. Harder to get to and clean.
http://p-car.com/diy/ac/
dave
dave
When you remove the air filters, look deeper below into the ventilation system.
You should be able to see the front side of the evaporator core.
Buy an A/C cleaning/disinfection spray. (One of those that come with a long flexible tube, that you can stick into hard-to-get-to areas)
Apply the cleaning foam generously and let is work for a while (15-30 min)
Also, on the 964 you can get to the rear side of the evaporator from the inside of the car, by removing the radio. I guess it is the same on a 993.
It's a bit fiddly, but a Hell of a lot easier than dismantling the innards of the ventilation system from the boot side.
I wrote a Thread about it a while ago: "Getting rid of foul A/C smell"
https://rennlist.com/forums/showthre...ferrerid=24395
Good luck!
Good luck!
+1 on looking beyond the filters, and not saying this is the case with your car, I had a friend with a SAAB that he stored for the winter and a mouse died in the vent hoses. It took him forever to find it and his car smelled even if the air wasn't on. Just fresh air open it would smell as well. Are the fumes smelling like something is dead or is it a stagnate smell? From my experience it is usually something other than the filter. They do make a disenfecting spray, but you have to figure out the smell.
Mike
Mike
You know those 'plastic containers' that you hook up to your hose - that you use to spray "Scotts Turfbuilder" or the like onto your grass?
Well, I use one of those - but i fill it half-way with Lysol (concentrated liquid) -- "lemon scent".
Then I attach the hose, flick the setting to 'fill' -- then when it's filled I open the valve and literally 'douse' the car with it (an Irish expression) and make sure that I get into every opening and crevice -- esp. the frontal area and the trunk (yes, yes, having first taken everything out...jeebers!).
To date -- no stinky car! ...and, yes, sometimes mine 'sits' for weeks on end during some of the crappier winters that we've had, here in the New Yawk area.
Gerry
Gerry
You got some mold in the AC vents. Usually it happens from being in a humid climate & keeping the AC on for longer time. The wet air stays in the vents after you turn the car off, & sits there, then mold starts to grow. The way to stop it from happening is turn the AC off before you shut the car & let the vents run for about 5min before you shut the car off. Do it a couple of miles before you get to where you are going.
To kill it, change the pollen filters, then get this & spray it in the vents.
http://www.detailersdomain.com/index...PROD&ProdID=41
Wow! Thanks guys for all your help!
budge96: where is this drain pipe located?
Stealth: Hope all is well. I'm ordering the Klima Cleaner today!
Gerry: You mean spray the interior with mats out etc?
Mike: not an organic decay smell; more like junior high locker room.
Jens: after applying the foam, do I wash it off or just leave it alone?
Re: Lysol.
I spray the 'Lysol concentrate' (via the garden hose) --
i) into the trunk (after having removed all carpeting, spare tire, toolkit, etc. etc!)
ii) into the door jambs
iii) into the front air intake
iv) and into the front 'louvres' just beneath the turn-signal-lights.
v) I also, once a year, take out the carpets and give them a good washing, 'finishing off' with a 'Lysol rinse'.
Not for nuffin' though, it DOES sound like YOUR particular problem has to do with 'mold' in the A/C pipes/ducts.
Gerry
Gerry
