993 Forum 1995-1998
Brake ducts - HELP!!
Old 07-07-2009 | 12:14 AM
jscott82's Avatar
jscott82
Default Brake ducts - HELP!!
Ok folks... I am completely baffled by this puzzle. First I thought it was impossible and gave up, saying: adding “real” brake ducts to a 993 is a farce. Then I see that Kelly Moss offers carbon fiber duct shrouds, so it seems they have figured this out, but they are out of my league (>1k for the shrouds alone), so anyone know how they did it?
First some ground rules:
1) The surface area of the “hose” opening must remain relatively consistent (no crips)
2) Wheels must be able to turn lock to lock (turning radius is bad enough as-is)
3) Exit of “hose” must vent into the center of the rotor, not just in the “vicinity”
I’ve seen several solutions that break one or more of these “rules”, never one that “does it right”. To solve 1 and 2, I’ve seen some folks bring the “hose” into the frame rail and use the frame rail as part of the pathway. Seems like a great solution, however, I have concerns ducting rain water into the rails. Any thoughts on that?
Where I am truly stuck though, is problem #3…. It does not seem there is any open space available on the backside of the rotor to connect the hose, even if I were to fabricate a shroud. Anyone figured out this piece of origami? See the pic of backside mockup…
http://i429.photobucket.com/albums/q...993Upright.jpg
Looking forward to your suggestions….
Old 07-07-2009 | 01:29 AM
jscott82's Avatar
jscott82
It’s funny how just talking about a problem, spurs a solution….. Right after posting this thread, I had a epiphany, and may have my own answer. A quick mockup with some cardboard and scrap aluminum, I think this will work… any thoughts?
http://i429.photobucket.com/albums/q...uctMockup1.jpg
http://i429.photobucket.com/albums/q...uctMockup2.jpg
Old 07-07-2009 | 01:35 AM
jdistefa's Avatar
jdistefa
I just wonder whether the stock deflector on the front part of the a-arm feeds more air to the rotor than anything we can come up with.... I guess the question is, how much will this additional airflow (very nice BTW ) help?
Old 07-07-2009 | 01:57 AM
Full Boost's Avatar
Full Boost
Why do I feel so left out!
Just to throw a spanner in the works....
IIRC for the ducts to be truly effective -the dia must be larger than than 100mm - and must be in the +ve pressure area... ie like Ram Air on some sport bikes. Not sure if these two are mutually exclusive or not....
There is a thread on it somewhere....
Scoops = prob better...?
Simon
Old 07-07-2009 | 10:05 AM
V's Avatar
V
This would be my bet as well.. I really like the a-arm solution that the 996 models use.. Just use the front ducts for additional cold air to the oil cooler..
Old 07-07-2009 | 11:28 AM
jscott82's Avatar
jscott82
My real goal is to extend the life of the rotors. Ive been running doubled "scoops" for years, and they do do a great job, but they are just keeping air flowing through the wheel opening. They dont do a good job of venting the vanes of the rotor. So the duct would be used to suplement not replace the scoops (although my car is so low now I have to go back to the stock scoops)
Old 07-07-2009 | 12:08 PM
Ag02M5's Avatar
Ag02M5
Is that compatible with 964/993 models? Significantly difference with what we have stock?
Thx.
Old 07-07-2009 | 02:56 PM
jscott82's Avatar
jscott82
Thx.
996 and 993 have similar sized (but not interchangeable) scoops on the control arms. These work pretty well, but in order to keep maximum ground clearance, they do not protrude much below the belly of the car... In the 996 world the GT3 has bigger (deeper) scoops that can be fitted to the regular 996 for added cooling. No such animal for 993 though.
However...... In a 993 the control arm is over an inch thick and the scoops mount to the top of it, so one option is to simply move the scoop to the bottom of the control arm for added effect.... I took that one step further and bought a second scoop, mounted it to the bottom, leaving the stock on top, and grafted the two together to form one larger scoop.... Unfortunately I broke these off in my wreck and did not replace them... so no picture to show....
Old 07-07-2009 | 03:10 PM
Spartan's Avatar
Spartan
I run a duct under the front diff cover that splits to run a 3 inch duct to each rotor. This setup works VERY well but only works if you have 2wd as the ducts run essentially where the front driveshafts would go. I used the CF brake duct hose connections for turner motorsports and fabbed them to fit with my 380mm bbk
I can tell you where to buy the ducts if you are interested
Old 07-07-2009 | 04:05 PM
Bill Verburg's Avatar
Bill Verburg
Because of the upright design in the area of the axle there's no way to duct to the eye, you can use dual 993 scoops or adapt Cup or GT3 scoops to the 993 arms, or make your own.
Of course you could also have some custom uprights fabricated too,
something like Robert Lintens Gem shown here, shouldn't set you back more than a few decades of spare change
Old 07-07-2009 | 04:32 PM
Spartan's Avatar
Spartan
If you bend the 3 inch duct to fit betweeen the caliper bolts (this is on a 993tt setup only) then you can direct air into the center of the totor. Its not "ideal" but it works. I ran this setup all last season and it worked really well
Old 09-01-2009 | 12:57 PM
JPS's Avatar
JPS
Pics and source?
Old 06-16-2011 | 12:17 AM
JPS's Avatar
JPS
bump?
Old 06-16-2011 | 02:51 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
What Bill says is right on -- you want to feed the eye of the rotor, not so much to face cool the inboard face of the rotor. Rotor core cooling is much preferred over face cooling.
If core cooling isnt enough, face cooling both sides of the rotor is the next step. This is commonly done by way of a rotor glove like this. Obviously this isnt a road car but merely some examples of how to get air to the source of the heat. Also in these images are pad cooling ducts. We've found the outboard pad to require more cooling than the inboard pad.
Other examples
Old 06-16-2011 | 10:19 AM
Bill Verburg
Here is the nicest 964/993 setup I have ever seen, I believe that this was done by Pro Systems in NC
Intakes in trunk floor, blowers in trunk
wiring
spindle duct for a 328mm Brembo NASCAR rotor, 322 would be similar but compromised by reduced space
wheel well ducting, this was for the stock 964 brakes
