993 Forum 1995-1998
Rotor Replacement Question
Old Jun 27, 2009 | 09:22 AM
sigf's Avatar
sigf
Default Rotor Replacement Question
How can you tell if they really need replacing? I need new pads all the way around, and one mechanics says the rotors are at the end of their life, and another who says that they are fine. There is no pulsating when braking, and no cracks anywhere on them either. The outside edge has a little "lip" on it maybe 1/16". Thanks.
Old Jun 27, 2009 | 12:04 PM
993inNC's Avatar
993inNC
Factory specs call for no more than a 7mm crack between vent holes. If they are 7 or better or if they cascade over the edge of the rotor then they need replacing. Its not recommended that you "turn" them, although a very light pass that doesn't take off anything but the tallest high spots wouldn't be bad. Just don't have them ground down like a normal "turning"
Old Jun 27, 2009 | 12:16 PM
Deadeye's Avatar
Deadeye
+1 very light turn, check spec for thickness before and after turning. I had mine done last year and they are working great. No track use however.
Old Jun 27, 2009 | 12:24 PM
ppressle's Avatar
ppressle
The rotors also have a minimum thickness. It is typically marked on the rotor hat somewhere. You should measure the rotor and compare that with the minimum. You can use a micrometer to measure it.
If you have 1/16" lip you do have some wear...
Old Jun 27, 2009 | 05:17 PM
mhm993's Avatar
mhm993
No cracks and a 1/16"--unless you feel something wrong when braking, you're absolutely fine. Check 'em when you next change the pads or bleed the brakes.
Turning not recommended, and at the price that you can buy new ones from Sunset, why bother anyway.
Old Jun 27, 2009 | 05:20 PM
Mark in Baltimore's Avatar
Mark in Baltimore
If you decide to ditch the front ones, let me know.
Old Jun 27, 2009 | 06:27 PM
Paul K's Avatar
Paul K
I just went through this. I was told that if there is a discernable lip around the edge, they are ready to be replaced. Mine did, plus when I took it in the shop told me they discs were not OEM. So I had all 4 replaced, with new OEM pads at the same time. Much better!
Old Jun 27, 2009 | 06:30 PM
NP993's Avatar
NP993
I just did too -- measured my fronts for thickness, and they're right at 30mm, the wear limit. So if anyone has a pair of front rotors for sale that are new/barely used, let me know. Otherwise I'll have to commit the sin of paying retail...
7 Porsche Models That Have Aged Like Fine Wine
Old Jun 29, 2009 | 10:07 AM
sigf's Avatar
sigf
Thanks for comments. I appreciate them. Gonna pull the wheel and take some precise measurements!!!!
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
