993 Forum 1995-1998
Speedometer acting funny - need some help
Old Jun 23, 2009 | 01:04 PM
Arena993's Avatar
Arena993
Default Speedometer acting funny - need some help
I did a search and of course it mostly covers the odometer gears. I am replacing the odometer gears on Wednesday, but noticed on a drive this AM that the needle stays at 0 until I hit about 15mph. When I hit 15 MPH the needle jumps from 0 to the correct speed of 15 MPH. The needle works perfectly through all speeds with no jumping or incorrect readings. It just jumps from 0-15 MPH from a dead stop to 15 MPH. If I slow down to 5 MPH and get in the gas the needle works fine also. So the issue is from a dead stop to 15 MPH. Since I am doing the odometer gear swap on Wednesday should I do anything else or should I check the sending unit since it is electrical and not gear driven. Also where is the sensor if I need to look at that? Thanks for all the help.
Mike
Old Jun 23, 2009 | 03:29 PM
Redblurr's Avatar
Redblurr
Mine does the same thing. Although mine jumps to 20mph. Curious to hear other thoughts and experiences.
Old Sep 25, 2014 | 04:26 PM
Chris V's Avatar
Chris V
Started having this same issue yesterday. Searched and found a few threads with similar problem but didn't find any that offered solutions so I thought I'd revive this one in hopes of some suggestions to correct it. Speedometer needle not immediately rising when accelerating from a dead stop. Odometer works fine. Speedometer works fine once the needle pops up to the correct speed.
I did flick the speedometer glass one time when this occurred which immediately resulted in the needled popping up from 0 to the correct speed of around 15 mph.
Anyone else have this problem and figure out the cause?
Old Sep 25, 2014 | 05:26 PM
pp000830's Avatar
pp000830
I don't watch the speedometer much under 25MPH.
Old Sep 25, 2014 | 06:11 PM
Vandit's Avatar
Vandit
I suspect this might be caused by the f'd up odometer gear. I say this cause my odometer failed last wk (was professionally repaired only 3yr, 7k mi ago, WTF) and I noticed that now my needle is doing a bit of periodic jumping around behavior.
Old Sep 25, 2014 | 10:11 PM
Redblurr's Avatar
Redblurr
Default speedo issues
Ya same problem as I had. Started out just acting up then went to poop. PM me and I'll tell you how to fix. It takes a special gear and taking apart your speedo. Easy dyi.
Old Sep 26, 2014 | 01:37 AM
Chris V's Avatar
Chris V
Ah...thanks, pm sent
Old Sep 26, 2014 | 11:46 AM
nine9six's Avatar
nine9six
Redblurr, now is your chance to contribute back to the forum. Why would you take your fix offline via a PM?
I'm jus sayin...
EDIT
And here we are 6 mos down the road, and narry a peep!
Maybe it's just like his status as a "user". True to all aspects of the word/title/status
Old Oct 3, 2014 | 01:52 AM
espanolie's Avatar
espanolie
i'm can't offer much help, but would certainly like to see what possible solutions from other members so i know what to do.
Old Apr 3, 2015 | 03:42 PM
Jeff U's Avatar
Jeff U
Mine did (is doing) this.
It began with a wobble in the speedometer while driving, then to the stays at zero before suddenly begin working, to be followed by completely dead.
I sent if off to North Hollywood Speedometer for repair. The technician said they replaced the circuit board. He said the gears were fine.
It's worked fine for about six months but is now acting up again.
Any ideas why the problem would reoccur?
The speed sensor was replaced a month before the speedometer repair.
Old Apr 4, 2015 | 06:49 PM
nine9six's Avatar
nine9six
Does North Hollywood warrant their work, and for how long?
I'd give them a call.
Old Apr 4, 2015 | 07:36 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Pull the speedometer and disconnect the wiring harness from it. Then take a look at the pins on the back of the speedometer. Are they mirror shiny or dull grey? You can clean them up with a pencil eraser (and then if you want, rub down with a contact cleaner like DeOxit, just don't rely entirely on the contact cleaner to fix this...) Our 993s are coming up on 20 years of age which is more than enough time for tarnish to accumulate on the pins causing all sorts of sporadic issues.
Old Jun 15, 2015 | 12:22 AM
Jeff U's Avatar
Jeff U
Update:
My mechanic found an intermittent faulty ground on the connection to the speedometer.
He corrected the ground and appears to have solved the problem.
So far so good.
Old Jun 15, 2015 | 01:19 PM
nine9six's Avatar
nine9six
Final analysis/fix was a ground wire located where, please?
Old Jun 15, 2015 | 09:01 PM
Jeff U's Avatar
Jeff U
I'll ask my mechanic for a clearer explanation.
