MY '02 Wheels
#32
Go get these then. The price is right. http://www.6speedonline.com/forums/a...ra-wheels.html
Senor Moffat, I have not been holding out. I just did the swap on Tuesday night. The photo is an iPhone pic. I'll take more when I wash the car next.
#35
Will the center caps from my cups fit these wheels?
Any other modifications required to run these? I thought I remembered that you need some kind of steering rack brace to run 18" wheels on early 993s, true?
#40
#42
Heh, I was outbid on another eBay set earlier today. Bid was in with a few seconds to spare, but not enough. Oh well, I may just stick with my old CupII's and order some HRTZ-III's for now.
Yes; http://www.pcarworkshop.com/images/5...996_640496.pdf
I don't want to hurt my baby.
#43
Make SURE you get pics from seller of outside AND inside of ALL wheels. I spent time talking to a guy with a "perfect" set of powder coated black MY02 wheels... Only after several emails and prompting, did he mention the re-weld fix and the pics showed flat spots on the outer rim that were obvious issues. Buyer beware!
My complete thanks to the RL'er who tipped me off to carefully check things out. Things were not "perfect" as initially described. One person's "perfect" may only apply to cosmetics....
ps. Sold.
#44
My VIN is outside the range as well. I posted the same question and was reassured by a few here. There are other threads on the subject that I found reassuring as well, when I searched a few months back. Considering some are running 19's and are OK, I would imagine a light set of 18's with proper offsets and standard widths of 8" & 10" (like MY02's!) should be fine. Judgement call, though.
#45
My VIN is outside the range as well. I posted the same question and was reassured by a few here. Considering some are running 19's and are OK, I would imagine a light set of 18's with proper offsets and standard widths (8" & 10") should be fine. Judgement call, though.
By the way, I am originally from the Seattle area, relocated to Texas 1990 and I can say I honestly have not missed the rain! It's not as pretty down here though...
Thanks for the info, good luck in your hunt for some wheels!
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
