I am not a crook....and need help!! (Locking lug nut issue)
Below is my post from 1/5/09.
You need a 12 point socket, can't remember size 11/16??, small sledge hammer, propane torch, small bucket of ice water, and 4 new lugs.
Use the sledge to knock the 12 point on and remove the lock as normal. I used rags to protect the wheels. After removing use the torch to heat the lug and socket for a few seconds and then drop it in the ice water and she'll pop right out. Move on to the next one. It took me a total of 20 minutes.
I like to leave the key on the lock and drive till she comes off. Then try to find the key. The second time I've done this. Fun huh!
Yes I put locks back on, but only because I had a set already. I'll be ordering lugs soon and never again!
I just so happen to have all my wheels off for a post autox/ pre next autox inspection
So here's a picture of my lock nut from the side as delivered by the dealer.
FWIW this is my second set of factory lock nuts. I lost the key to the first and tried the mentioned 12 point socket + hammer + painters tape (for scuff protection). I probably did something wrong but the top of the lug nut simply snapped off so I was left with the bottom part of the nut and didn't have a socket deep enough to get at the rest of it (see image). I drove it to the dealer and they had a master set, popped the old ones off and put the new ones back on. No charge beyond the parts (thanks Porsche dealer at Liberty Lake).
![](http://i120.photobucket.com/albums/o186/Bleu24/lugnut.png)
