993 Forum 1995-1998
Weight loss for a 993
Old 06-04-2009 | 03:12 AM
Wilder's Avatar
Wilder
Seats make a big difference. My supple leather, full power and heat seats weighed in at 78lbs/ea on a commercial scale. The CF GT3 seats I installed weighed 14lbs each without sliders. You can get sliders at ~15lbs/ea. That's an easy 100lb loss.
Old 06-04-2009 | 10:38 AM
Bill Verburg's Avatar
Bill Verburg
the interior is a good place to start
floor carpets and the foam pads under them can be replaced w/ aluminum floor boars, add mats for street use
seats, stock leather fully electiric w/ sliders weigh ~52#ea, Recaro SPG XL w/ al. mounts and sliders ~28#ea
door cards to RS versions
lower dash to old style, steering wheel to non a/b RS version
rear seatectomy
r/r rear upholstery panels w/ foam and l/w carpet versions
sunroofectomy would remove a lot of weight up high
exhaust is another good candidate because of where the weight is at the extreme rear. r&r cat w/ cat by pass pipes
engine mounted blower & pipes, SAI if you have it(RoW don't)
front trunk
use RS washer bottle, delete stock one
remove carpeting
wheels
MY02 996 5 spokes are pretty light 18s @ 20.5/22.7#, w/ MPSC 39/42#
you can go crazy and drill the bumper backing for a few more #s
Old 06-04-2009 | 10:54 AM
Reddy Kilowatt's Avatar
Reddy Kilowatt
Originally Posted by trophy
I never said they were accurate, however the RS door panels you refer to one is with and one is without speakers, which is in the list.
For accuracy I just weighed the hood struts, they each weigh (front or rear) 6oz each (total of 24oz), so you are right definatley not a lb front and rear but every oz counts.
I am working on the items I have removed from my car and will post when all weighed up
Every ounce counts... but only once.
Old 06-04-2009 | 11:20 AM
trophy's Avatar
trophy
Originally Posted by Noah
Oh, I know -- my comment about your list being compiled from the archive was intended to make sure people knew that this wasn't your personal list. Sorry if that wasn't more clear.
No worries... My plan is to weigh everything that comes out of my car, I will compile an accurate listing then. there is a lot of guessing when it comes to removing weight from our cars.
Old 06-04-2009 | 11:29 AM
fast_freddy's Avatar
fast_freddy
I dropped two pounds off my 911 this morning.
Old 06-04-2009 | 11:31 AM
TheOtherEric's Avatar
TheOtherEric
Here's what I did first:
1. Seats. Replace 8-way power seats (50 lbs ea.) with fixed back race seats (30 lbs ea. with sliders)
2. Cats. Replace stock cat (30 lbs) with sport cats (16 lbs).
3. Mufflers. Replace stock muffs (34 lbs total) with RSRs (19 lbs)
4. Wheels. Get some 18" wheels weighing 21F / 23 R. E.g. MY02, hollow spoke twists, etc.
5. Rear seats and seat belts. -15 lbs.
Old 06-04-2009 | 11:37 AM
RickBetterley's Avatar
RickBetterley
Not to be difficult or a nitpicker, but I don't think you can get 200 pounds out of the car by removing these items. The dash and battery save around 30-35 pounds. The door panels save 5-10. That means the stock carpeting and sound deadening weighs at least 150 pounds, when it doesn't weigh half that. Maybe the Motons are lighter than stock, but probably not by more than a few pounds per corner.
Hi Noah
Not nitpicking problem at all; I appreciate the input.
I was reporting on what I was told, but the list was probably incomplete (and therefore misleading; I will edit the original post). Other changes to the car include deletion of the rear seating and belts, installation of 2 race seats instead of stock fronts, and other racy things that must have been part of the 200 lbs.
Thanks for the input (on my own car, no less!).
Thanks for the corrections
Old 06-04-2009 | 12:53 PM
Smiles's Avatar
Smiles
Wow, Steven! Great list. Even if not extremely accurate, it's very helpful.
Old 06-04-2009 | 01:22 PM
SuperUser's Avatar
SuperUser
Does anyone know what the weight difference is for pss9/10's from stock?
Old 06-04-2009 | 01:37 PM
TheOtherEric
I'd be amazed if there was a substantial weight difference one way or the other. Having just recently had my stock & PSS9's off the car, neither seemed light.
Old 06-04-2009 | 02:25 PM
SuperUser's Avatar
SuperUser
I have a set coming from viperBob I will put them on a scale before I install them on.
Old 06-04-2009 | 02:39 PM
Cactus's Avatar
Cactus
Noodle Jr.
Old 06-04-2009 | 02:57 PM
944/951guy's Avatar
944/951guy
Removing the engine and replacing it with a 1966 912 engine also works.
Takes out about 300 lbs.
Old 06-04-2009 | 03:19 PM
jungleboy's Avatar
jungleboy
anyone care to correlate each weight saving item to $$$$ please
or shall we all remain blissfully ignorant and do it anyway
Old 06-04-2009 | 05:32 PM
trophy's Avatar
trophy
Ignorance is bliss.......
Quick Reply: Weight loss for a 993
